IH 650 Hydraulic Fluid
all depends if you have different tractors using the same hyd. cyl. back then just the ordinary hyd. oil was used. if using newer tractors also then stick with the hytran oil, so its all the same oil not to contaminate stuff. motor oil is ok also if that is the only tractor u have using impliments.
