Lumbersawyer
- Location
- Grand Rapids, MN
I have a 1929 10-20 McCormick that has the up graded governor throttle control instead of a fixed Hi idle that they came out originally. The previous owner had a really poor linkage back to the right hand fender. I would like to install the factory type throttle linkage I found on a salvage tractor that I think are the right parts.
Does anyone have a picture of the throttle pull linkage that they could post or send me? Any pictures I have found are in front of the fire wall not behind in the drivers side.
My tractor still has the spark and throttle levers by the steering column. That throttle lever does override the governor and will idle it down, but, not as nice as the governor throttle control that I could use. The poor throttle linkage that I had on the RH fender did control the engine speed much better than the override lever. I would like to have better control of my engine speed when belted up to various machines and a nicer looking set up.
