52 Farmall super A 12 volt
I'm getting very close to starting my A for the first time . Although I took many pictures I can't remember where the negative wire from the battery grounded to the tractor.
Any advise would be appreciated
Brian
The best way is as close to the starter as you can. On most I try to ground them at the starter mounting bolt.
On my 53 SA (now 12v negative ground) its landed on a fine thread screw on the back side of the "dash" which is the metal stamping holding the ammeter and the start push-pull switch.
