Noise in Trans on B Farmall
I have a noisy drive train in my B, only when going forward, some in all gears, more in 4th. There is hardly any noise when in reverse. Would one be able to pull the axles from each side and swap sides and then do the same with the large bull gears. That would give you a newer surface to be meshing against and seems like it should be less noise. Any thoughts? Or, could you remove the final drives from the trans and swap them? That would also reverse the wear sides.
The input shaft bearing was what made all the noise on mine, of course that was after I went through the final drives and replaced every bearing that looked the least bit suspect.
