Farmall Regular Carburetor Float
It's time to replace the old cork float, in the carb, on the Farmall Regular. I've read that some have switched to a brass float, from a Briggs and Stratton, or some other engine. I assume that the process is to unsolder the float lever on the Briggs float, and to solder the original Farmall float lever on. Can anybody tell me what Model or P/N Briggs float to look for? Have some of you had good results, from doing this?
As mark said below or Alderson tractor. and Fordson house have brass floats for 10-20 and Regular. Work and last much better than cork.
