F300 TA pressure plate fingers
Bkpigs
My pressure plate fingers for the TA on my F300 got out of adjustment (not equal heights). Trying to adjust them without splitting the tractor. I am able to adjust them but the manual says 1-5/8" for the height. If I adjust them to that spec, they are below the height of the adjustment nuts. Is that right?
I believe you are OK with the adjustment as you noted. The K dimension is also important. The TA
throwout bearing adjustment and linkage function depend on these to a degree. Remember that the TA
clutch friction plate wears and that the finger adjustment is not usually needed. Uniformity and
being close to the spec are mandatory. Jim
(quoted from post at 01:16:22 09/09/18) I believe you are OK with the adjustment as you noted. The K dimension is also important. The TA
Thanks. Yes the K measurement is correct.
