300 INTERNATIONAL UTILITY FACTORY POWER STEERING
JJ in NE
I am looking for pictures of an actual tractor or some kind of diagram showing how the factory power steering system on this tractor is set up .I have a 300 utility w/o power steering and have purchased a ps unit and a valve from a salvage yard in the NE part of the U.S. I would like to install this on my tractor because it is one of the handiest little tractors i have came across.I guess my biggest dilema is this valve I have, how to plum it in the system or do I install an aftermarket divider valve like what is used on the CHARLYNN POWER STEERING systems?Can anyone help or lead me to some answers?
I do not know for fact, but I think that if it was not PS from the factory, it would not have necessary passages and provision for their use.
(I may be wrong) A priority valve is needed, or a second PS pump driven by the front pulley. Either will do the trick. Look in the parts diagram to see if the Power steering accessory includes different reservoir and connection parts. Jim
I looked at a parts diagram in a parts catalog at my local dealer and it shows an additional valve where the remote and fast hitch valve are located. The valve I received from the salvage yard looks as if it might be from a farmall but I am not sure. Thanks for your help. JJ.
Pics of hose routing and connections were sent to your email address. Hope they help explain the setup.
Thanks for you help Sentry this is exactly what I have been looking for. Sorry I did not get back to you sooner . I think I can figure it out from here. THANKS AGAIN!! JJ.
I have the very same IH 300 Utility that I am trying to put a factory power steering on. I have the priority valve and power steering unit but need to check the plumbing connections. If you could send me the same diagrams it would be very helpful.
(quoted from post at 03:04:52 04/24/10) I am looking for pictures of an actual tractor or some kind of diagram showing how the factory power steering system on this tractor is set up .I have a 300 utility w/o power steering and have purchased a ps unit and a valve from a salvage yard in the NE part of the U.S. I would like to install this on my tractor because it is one of the handiest little tractors i have came across.I guess my biggest dilema is this valve I have, how to plum it in the system or do I install an aftermarket divider valve like what is used on the CHARLYNN POWER STEERING systems?Can anyone help or lead me to some answers?
Ican send some pic`s of the piping , but my PS unit has been removed for repair direct email is badguns @ yahoo.com
