hello every one, new to the forum. i recently picked up a ih b414, thing would hardly run when i went and looked at it ended up having to come along it onto trailer. but did see it run and see the hydraulics worked. got it home filed and adjusted points and drove it off trailer ran decent but had no power in high range. did more digging and found it had a blown head gasket between cylinder 2 and 3. replaced that along with a new coil and tractor runs great no smoke no knocking. worked it for 3 hours yesturday cutting ditches and i have found a problem i believe. oil pressure goes from a strong 40psi idle cold to 8-10psi idle hot and 15psi high idle. so it would seem the ole girl has some hours on her. but it dosnt burn oil, dosnt knock,fires right up, didnt see any thing in oil when i dumped it. im thinking this is a oil pump related issue. your thoughts?
