OK, all you knowledgeable IH gurus; My 574 has too good of brakes, she just came out of a shop for some work, had to replace the 540 PTO shaft so seeing as the top cover had to come off it was time to replace the parking brake and as long as they where into it that far fix the main brakes, the right would always leak down and require bleeding the left was always strange it would build up and apply itself, you would have to bleed fluid to release the brake. The brakes were a pain $$$$$ this is an early unit and new brake discs where not available so the shop retro fitted newer pistons and plates and new discs, rebuilt the master cylinders and then replaced one with a new one. The equalizer has been bypassed. The brakes still apply themselves and the only way to release them is to relieve pressure at the bleeders. the restriction orifice is installed as are the individual screens. Any thoughts or ideas?
