Janicholson
The 706 has a hydraulic apply direct clutch in the TA, using a multi disk clutch pack. TA apply pressure comes from MCV pump and
control. Does it shift to direct with the lever forward? If it shifts weakly or stays in the reduction ratio, it either has a
valve adjustment issue in the TA control, or a hemorrhage in the TA direct clutch apply servo. Jim
