F30 sleeve puller
All looking for a sleeve puller for an f30. Innermost r bore of
the sleeve is 4.25 and outer bore is 4.75. Was getting coolant
into cylinder and tore it down and found 3 sleeves really
smooth and clean with one pitted and scuffed with a hole in
the sleeve. I?ll try to attach pics so you can see but really
need a sleeve puller.
(quoted from post at 09:17:10 08/31/18) All looking for a sleeve puller for an f30. Innermost r bore of
I have a machined puck to fit the bottom of the sleeve you can have if you want it. I made iton my lathe. Youll have to buy some hardened all thread and hardware though to use it though.
Be interesting to know if you know the tractors history? It looks to me like the pistons was stuck pretty good at one point in that cylinder. I would say to the point that the head had to be pulled to get it loose. Seems to me someone took a big chance putting it back together with a sleeve that rough.
Well when I got it, it was stuck in cylinder 2 but not really bad. 1,3,&4 were all good loose and I honed everything out really good and there was no defects. I had thoroughly inspected number 2 and there is still no issues pit or gouges. Number 3 is now the one in the pictures and did not look like that way at all before or I wouldn?t have put t back together.
