Mccormick 33 loader
Fred47M
In case i cant get the lift cylinders working again,heavy pitting on them. Does anybody know of other implements that use approximately 48in overall length , 36in stroke, 1.5in rod. 2 way. That i could look into getting- used, if thats even possible. Thanks
Two ways to go in my mind. Either go through a hydraulic repair shop and they can fix you up with new rod stock or check Craigslist for a parts unit. I've been seeing 31 and 33 loaders listed lately. I don't know if Baum Hydraulics are still in business but they used to have a catalog that you could order from.
Odds are that repairing the cylinders will far exceed the value of the loader, especially if you need them to turn you new rods. Same goes with replacement cylinders.
I agree with NY986, another loader is probably your best bet. Hopefully one that was stored with the cylinders retracted.
