farmall pete
Have a 656D with a roosamaster pump. Was leaking at banjo fittings so I installed new sealing washers. That stopped it for a few months, but now they are leaking again. Tried loosening them until fuel squirted, then tightening them down. Did this 3 or 4 times. Still leaks. Drip drip is the same rate no matter how tight the bolts.
How much can I tighten them? Any other solutions or tricks to this? Do the washers get deformed if tightened too much so they will no longer seal?
