C135 Cam Gear Press Fit
I am rebuilding a C135 engine and I in the process of putting it back together. I had the cam and the lifters polished so I had to press the cam gear off the cam. My question is pressing the gear back on the cam. Is there a hard stop for the gear as you press it on the cam? I pressed the gear on till it was making full contact with the crank gear and the cam retainer had just a little resistance to turning. Is this correct?
OTJ
