Transmission leak through fender bolt
RTR
Working on a 1975 Farmall 140 right now and upon removing the fender on the carburetor side, I pulled the 2nd bolt and a solid, steady stream of gear oil from the transmission started pouring out through that hole. Do those holes that hold fenders on go all the way through the transmission case? I've removed several over the years to clean and paint and have never had that happen. Granted if they do go all the way through that means that the transmission is over full because the other ones never have leaked after I had changed the oil. 4 1/2 quarts is all I ever put on them. 5 quarts with right angle PTO.
Just wanted to confirm nothing major is wrong with this one since it started leaking. I immediately put the bolt back in and will wait until tomorrow to investigate and I'll also go ahead and change this ones Oil too.
The casting likely isn't very thick at that point because it's the side of the transmission case.
So the threaded hole may not be "blind".
Just for giggles, why not take the bolt out at the same location in the other fender, and see what you find?
(quoted from post at 23:27:21 08/26/18) The casting likely isn't very thick at that point because it's the side of the transmission case.
Bob it is an offset tractor so the fender bolt over there is not in transmission case. Maybe the platform bolt is. I drained oil out of tranny and there was almost 3 gallons or so. Way too much.
I haven't found out why. But yes possibly it goes all the way through and the overfill might have caused that. No water was in there other than the amount mixed in with the oil to turn it a milky color.
Yes this hole only goes all the way through. Not sure why guess it was ddfect at factory. I will put permatex on bolt when I reassemble.
On a second note...you never know what you'll find between the fender and transmission of a tractor like this. Haha. .
There is supposed to be a felt pad between the fender and the transmission. Not good if it holds water but I suppose that dirt(dust) jammed in there would not be any better.
(quoted from post at 02:33:06 08/27/18) There is supposed to be a felt pad between the fender and the transmission. Not good if it holds water but I suppose that dirt(dust) jammed in there would not be any better.
Yes that pad was still there but of course no worth reusing. You can see it on the left side of the fender. It is made from jute material.
(quoted from post at 17:16:50 08/26/18)
Hopefully that one bolt was not too long for the hole and popped the casting.
(quoted from post at 07:33:21 08/27/18)
They were all same length and original bolts. About 3/2 inch to 1 inch long. You can see them in the picture.
Pull it apart and look on the inside where that bolt is. Could be broken out from someone putting a too-long bolt in there. Could be an air pocket in the casting. Could be that way by design.
If you've got others, pull that bolt and poke in with a wire. If it's open, it's by design. Otherwise it's damage or a flaw.
At this point it is really neither here nor there. Time has proven that it is not detrimental to the operation of the tractor, AND your tractor has excellent axle seals. Clean it up, put it back together, and run it.
(quoted from post at 18:21:09 08/27/18) Pull it apart and look on the inside where that bolt is. Could be broken out from someone putting a too-long bolt in there. Could be an air pocket in the casting. Could be that way by design.
I'm gonna seal that bolt and run it. Just trying to figure out why it was that way. I'll check others in the future. With a screwdriver it felt like a flaw/air bubble in the casting. The hole felt like it was at the upper side of the drilled hole.
Most likely in my view, someone had it apart in the past and put too long a bolt back and popped the inside of the hole out when they tightened
the bolt. Easy to do.
(quoted from post at 23:21:23 08/27/18) Most likely in my view, someone had it apart in the past and put too long a bolt back and popped the inside of the hole out when they tightened
All bolts were original and same length. No worries though. Thank you all.
