Working on a 1975 Farmall 140 right now and upon removing the fender on the carburetor side, I pulled the 2nd bolt and a solid, steady stream of gear oil from the transmission started pouring out through that hole. Do those holes that hold fenders on go all the way through the transmission case? I've removed several over the years to clean and paint and have never had that happen. Granted if they do go all the way through that means that the transmission is over full because the other ones never have leaked after I had changed the oil. 4 1/2 quarts is all I ever put on them. 5 quarts with right angle PTO.
Just wanted to confirm nothing major is wrong with this one since it started leaking. I immediately put the bolt back in and will wait until tomorrow to investigate and I'll also go ahead and change this ones Oil too.
