Super H front hubs
4010tim
I am looking for a set of front hubs for a super H. I think I have found a set, but was wondering if I'm looking at the right ones. The number on the hubs is 8274DB. Are these the right ones to use with the adjustable front rims? (The ones that have the loops on them, not the wedge type)
Yes that's the correct casting number. 8274DA will work but casting is thinner at bolt holes for the rim than 8274DB.
Thank you. I was unaware of the DA casting and the differences, I think either will be fine as all this tractor is going to do is pull a v rake and run an elevator/auger occasionally.
