So I finally got around to finding and I hope fixing the fuel leak in and around the leak at the injector over flow lines. I still need to do 2 of the lines but at this time they are not leaking. Not even sure if the 2 I replaced where leaking. I did find the banjo bolts at two of the injectors where not as tight as they needed to be so in turn they leaked. Put on new hoses and then tighten the banjo bolts and leak stopped. I want to replace the front most hose but it is a bear to get to plus replace the longest hose but it seem to be holding up well so not sure if I will replace it as of yet
