1940 Farmall A
I wanted to know the best way to access and weld a new shift arm on my A.
Dont want to do it while it is on the tractor. I removed the pin,spring,cup and rubber gasket to see a pin that holds the spherical part in place. It looks permanent. So do I remove the whole cover? What would someone do?
There is a short arm that someone welded on in the past. It is too short and sloppy.
