585 Proper clutch assembly lubrication
ccaissie
What's the recommended clutch lubrication on the splines for the 585 Case IH.
The disk is sliding on one set of splines, the cover plate engages another spline set.
Grease?
anti-seize?
Dry?
Any other lube and prep hints before this baby goes together?
thanks to all for previous thread feedback on the clutch questions.
C
When I lube the splines,I like to use a non-sticky lubricant.My favorite is called track lube.All you need really is to be slick enough to slide together when assembling.The disc barely moves when releasing or engaging the clutch.Mark.
Thanks. I've got some NASA Krytox. Can't be too careful on these deep assemblies...ain't like changing an air filter...
C
Yes, rear main seal replaced, crank seal face looked good.
Replaced entire transmission seal set, had to grind a bit on the worn splines for insurance to fit right, and it all went together well.
Thanks guys.
