560D fuel leak
44 massey
I have a 560D that has a fuel leak at the injector pump!! Its leaking around the throttle shaft on the shutoff lever side!!!! Leaks regardless of shut off position!! I suppose there are seals or ?O? rings that need to be replaced???? Is this something that can be done without removing the pump???
Replacing the throttle shaft O-rings isn't really "high tech" and can be done with the I.P. in place.
It just takes some attention to detail. And having an IH injection pump service manual certainly doesn't hurt. (ebay)
Should turn out just FINE for a seldom-used parade tractor, for one still earning it's keep full-time and generating INCOME, I agree with techdiesel
