340 rear wheels
I have a 340 Row crop that had 36 inch rears on it when we got it but has 38s on it now. I adapted wheel centers off an H to fit the rear axles of the 340 so they would fit. Not sure which model of 340 you have but if it is a utility the wheel may mount different then the row crop do. If you have rear rims what have 8 hole and lug nut then you could go with 28 inch rear rims if you find the right bolt pattern
If I am not mistaken, it is a standard 8-on-8" bolt pattern used by millions of tractors of many brands over the years. As far as where to find some, try a local tractor salvage yard, classified ads, etc..
