340 utility 1962
do a search on that tractor and you most likely will find several photos of it. I suspect utility will have the white as industrial usually all yellow as mine is.
if its the undustrial then its yellow where the red would be on the standard utility and should have the white grill and white sides under hood.
(quoted from post at 08:34:21 08/19/18) if its the undustrial then its yellow where the red would be on the standard utility and should have the white grill and white sides under hood.
Yep, mine is a Gubmint Industrial, and has that paint scheme- has IPTO, but no T/A, hitch or hydraulics
Thanks for the info I think I'll go with the yellow with the white trim. The wheels I saw had white centers with silver rims.
:D :D
