Farmall cub
gidtex
Farmall cub with all equipment for 500.00.doesnt run motor does turn over.it has the chrome farmall emblem on hood.sheetmetal is rusted but in good conition.tires hold air,what year could it be,is it worth 500.00
Can't tell you the year but depending on what all equipment goes with it $500 could well be steeling it. I know if it was in my area it would be here yesterday
Does it come with any implements like a mower deck or snow plow? Or just the bare tractor? The rock shaft hydraulics are a good feature to have.
On one hand lots of soil plowing in a small tractor can be pretty hard on it...but on the other hand if you get the tractor and all of that its a pretty good deal imo.
Assuming it is a rounded hood and not a flat one the chrome emblems would probably be 58-63. Serial number should be on a plate behind the steering shaft where it enters the gear box.
(quoted from post at 20:50:01 08/18/18) Assuming it is a rounded hood and not a flat one the chrome emblems would probably be 58-63. Serial number should be on a plate behind the steering shaft where it enters the gear box.
Can you find the cast number on the block or clutch tube? The numbers will tell the month and day and the letter the year an example is like my Cub is 2.12.T That makes it Feb 12th 1950.
(quoted from post at 16:17:20 08/16/18) Farmall cub with all equipment for 500.00.doesnt run motor does turn over.it has the chrome farmall emblem on hood.sheetmetal is rusted but in good conition.tires hold air,what year could it be,is it worth 500.00
plows and belly mower and tractor = good deal
(quoted from post at 00:19:32 08/19/18)
hat is when the castings were made. They were allowed to age a few months before machining and assembly.
