Ih (?) disc plow
Seen this disk plow online
Listed as ih. Any idea the id?ing features to determine make/model?
Is there a tag? Name stamped?
Thanks
Posted in implement alley as well
Probably not as common as disc plows. Probably not that hard to find if you are somewhere they actually used them. I have no idea of value.
Looks like a 10 disk JD one way. Very common back in the fifties around central Texas . 8 disk were common also. Farmall H or Ford 8n pulled an 8 disk but it took a farmall M or an NAA with weigh to pull a 10. JD made a 14 disk with hyd lift that was very popular and could be pulled with an M just in one lower gear. I used a Fordson power major with my 14 disk.
Value is scrap value because of ground drive lift and hard to haul. If you tried to turn right the whole plow would flip over...BTDT
Its for sure ihc as thats stamped everywhere
Bought near mitchell on. 500$. Look good at shows. Working condition
