Dirtkeeper
New User
Hello everybody
I think i am in over my head. I have a Ih 3444 loader with a 3414 backhoe. I have had it around my property for about 25 years and had a new engine installed about 15 ago it runs great. Anyw ay last year My clutch got stuck in that i cant shift itout of gear becaus ethe clutch wont release. Ithink it got water in over the winter and as far as i can tell is rusted to the flywheel. I tried loosining the clutch from the access hole and previous to that tried running the tractor up a hill or into a pile of dirt to break the clutch free and could not. I tried to get a local tractor repair guy to come out and fix it but he never showed up and doesnt respond. I think he is busy doing easier work.
Any how i finally figured i am gonna have to fix it myself so i decided to pull the engine and dsimantle the clutch. Well it has been a trying experience. I am pretty good with stuff and have built a lot of vws and fixed things . But this is biigger all around
Any way i thought i was going to be able to pull the engine out the front and up but now that i got it stripped enough to remove i can only get it about an inch out before it hits the front mount, which is a loose mount in that it just sits there and holds the hydraulic pump, but it is inthe way of pulling the engine out. Am i going to be able to do this ? Or do i have to split the tractor? Any advice would be appreciated . I have some manuals and parts books but i am just not sure how this thi g is supposed too come apart or if splitting the tractor is necessary . I hope not. That sound like a hard job if i dont have another tractor to move things around.
Thanks
Thanks
