When I got my 350D Utility, someone, in their wisdom, had bypassed all three fuel filters, which of course is a somewhat complicated system, and installed a little inline filter in a rubber line, no good for a Diesel. It ran, but would start to heat up a bit, probably running lean from poor flow. Off the trailer and parked. I have come up with a stock- looking, much simpler setup that should work OK, using my memory of the twins on our 706Ds when I was a kid. Seems the 504D used just one of the same filters, like the final on the 706D, same canister- so I found one off a 504D on epay and plan to install on the 350D where the original big filter was, right by the pump. Any reason this won't work? I'm thinking they are similar size engines, flow requirements should be similar
