Rear main oil plugs
Bkpigs
Should these plugs be extending from the plate like this? Should I just trim them? I can't get them to go up any more when I installed them with the plate removed.
I suspect they need the be trimmed, at least that is what I do when I run across this. I would have
been sure before installation to measure the depth of the hole to be certain they bottomed out
properly.
(quoted from post at 11:38:10 08/12/18) Should these plugs be extending from the plate like this? Should I just trim them? I can't get them to go up any more when I installed them with the plate removed.
They should go in all the way.
