Hello, a while back I posted about an issue concerning my forward/reverse shift lever broke. I have installed a new shift lever and now I have put things back together. Now, I have another issue. I think my shifter (external) is out of time. When I put the new shift lever in transmission I moved to forward gear to be able to have better access to the nut. I went in from the top of transmission. (But, the shift lever broke in reverse initially). Now, I can't get it to shift into low range or reverse. I unhooked the shifter handle and moved the shift lever out of forward to reverse without using the handle but it is still in high range I believe. I haven't even put the hydraulic fluid back in yet. I am not going to start tractor until I know it is shifting correctly. Any insight would be greatly appreciated.
