Early 1947. Look at the date codes on the right side trans case, Looks something like this:2-15-Q(Feb.15,1947). This code will be on the major castings.Motor,Transmission,rearend,wheels.......
Thanks. Friend's dad had one they are trying to sell. Engine seized from sitting 5 years (starter won't turn it over). Has a cable-bucket loader with grapple, pto pump, behlen power steering, almost new front tires, good firestone f151 15.5-38. His brother says it steered real easy.
Lol, i follow your videos and one time you mentioned your number, maybe on here. so i wrote it down just to see how close it was to mine. It was sitting here by my computer and accidently wrote that as mine. Mine is 132270. Delivered to st peter mn mid may 47. Sorry to make you go check kenny!
Fred better recheck numbers. That serial number 127232 was built in Feb. 47. Rear housing is dated after that, maybe switched if the serial number checks out.
No I goofed, I wrote down the number of kens M, And I was going to compare to mine because I knew his was a minnesota tractor too. thought maybe they rode up together, lol. And in my pile of notes and scribbles by my computer I accidentally wrote down his on here. My fault. Mine is 132270. You are right, mine also a 3-18-47 on steering pedestal between tires. I think grandpa told me it was delivered in middle of planting, thats why i guessed mid may but He could have said harvest and i missunderstood. thanks!
My fault didn't notice the correction. 132270 was built in April. Grandpa was close so tractor didn't spend a whole lot of time from factory to dealer to Grandpa.
(quoted from post at 18:27:37 08/12/18)
The serial number listing is not coming up for me.
How so?
What happens when you click on this link?
http://www.yesterdaystractors.com/cgi-bin/snlookup.cgi?mf=FARMALL&md=M,+MD,+MDV+and+MV
If you're using modern view forums, you have to go out to the YT homepage and access the serial numbers listing from there.
