Meangreen
So I'm in the process of fixing/replacing some items on my M as suggested to me in a post on here about a month ago. In the picture above I plan on replacing the two springs. As of right now if the throttle is pushed all the way forward or pulled all the way back the spring on the left is fully compressed. In other words what you see doesn't change based on throttle position. So a couple questions:
1. The block with the arrow pointing to it, is that supposed to slide along the shaft? Mine is stuck in one position and I don't want to tap it with a hammer to break it loose if that's not the way to remove it.
2. When I reassemble I imagine the block should be in the exact middle of both springs, so that both springs are compressed the same?
Thank you
