W9 with fuel pump?
55 50 Ron
There is a W9 for sale in the photo ads. Sure looks like it has a fuel pump. The gas tank is higher than the carburetor so it shouldn't need a fuel pump. Anyone know the reason why there is a fuel pump if that's what it is?
Yep, they had a fuel pump. Yep, it wasn't needed. Been running one for years without the pump when it failed. Just install a line direct and gravity works well.
yes, they came with a fuel pump. i believe it was to make sure it had a good supply of gas on a hard pull with that big engine.
Never had a gas starvation on a hard pull just using a direct feed fuel line. Pulled a 5-14 plow and 10' one way disk plow without problems.
