SadFarmall
My F12 tractor project is getting closer to something I can use. Latest part is getting components for lights. I managed to find a headlamp, which is almost correct, except that the bracket is set up to be on the bottom instead of on the side. The lamp is being modified to fit F12 properly. I have not found other 'correct' parts, so I have done what would have been done here in the 1930s; found some Lucas parts. Ammeter, reverse lamp, headlamp switch, generator and regulator Not what IH would have fitted, but it is mostly from the right era and should look neat enough on the tractor. Not sure about the switch, might be able to find one without the centre ON switch, or just use it for a generator warning lamp.
First two pictures are of the tractor as it arrived before dismantling.
SadFarmall
SadFarmall
