Grease for upper bolster
Bkpigs
Rebuilding the front bolster on a Farmall 300. It has gun grease in the top around the gear. Is this correct or should it be oil or corn head grease? Thanks
go with the corn head or oil and grease concoction.
gun grease will never get to the sleeve below the sector.
greasing the lower bolster sleeve is easy but getting grease up to the lower bolster thrust bearing is a challenge.
I'm gonna try the suggestion as mentioned in a post below at my next maintenance time.
