Roger Tomfohrde
So I split the tractor at the transmission to T/A housing. Replaced the seals and gasket and the bearing. Now I am trying to get it back together and it is binding at the 5th speed gear set(I believe). The lower PTO shaft appears to be engaged and there is still a small air gap before the T/A quill engages the main shaft bearing. I have tried raising and lowering the joint to see if it would go. I have two long bolts through the halves as alignment pins. I have tried rocking the tractor and it does not seam to help. I have separated it once to try a slightly different angle of the gears but no luck yet.I quit for the day because of my job that actually pays me something.Is there any advice on how to do this without forcing it. Usually when I force something it breaks something.
