Adrian Billheimer
Just had a different noise come from the tranny area on my Super A while I was mowing. It was a very low tone that sounded like the word wobble, wobble, wobble, as soon as I pushed in the clutch it slowed down and stopped with the rest of the tranny noise. I just took the shifter plate off to look around inside, I found nothing out of the ordinary, except, the forward gear slider gears have a little twist play I'll call it, on the shaft, not turning play like backlash on the shaft, but if I grab the sides of the gear, I can kind of twist it on the shaft, not a lot, just a little.
It only made the noise for less than half a minute, guess I go finish that part of the yard and check back.
Thanks for any help or suggestions.
