I trying to fing an electric start setup fo an F-30
I know there far and few between but thought it was worth asking here. If anybody might have one or know of one please give me a shout. Thank you in advance.
I plan on putting a Chevrolet flex plate between clutch and transmission this fall . Perhaps if you do not find a proper set up we can share information. Put such on an F 12 years ago. Also built a belt set-up on F20. The 20 does work but not well, therefore plan on the flex plate route also. Care must be taken to not spin the engine too fast as impulse will not work properly .
I saw someone that mounted a ring gear to the inside of the flat belt pulley and bolted a starter to the tractor between the fuel tank and engine. They just jumped it off a battery to start it.
I know that i can make electric start setup using pto/ belt pully by adapting flywheel and starter but i would rather try my luck at finding the impossible to find. You never know, someone might just have one and be willing to sell it.
