Ellis Kinney
Found a really loose wire!!! As luck would have it the wire from the push/pull switch was really loose at the voltage regulator. I also soldered a couple of
connections and re taped them. All other wires are exactly as described.
OK-- I AM NOT GOING TO DO THIS---but what would happen if the tractor was started without the governor on the tractor??? Just curious. Ellis
