Ellis Kinney
Jim, you responded to my SMTA electrical problems yesterday and your answer I was kinda able to understand. You said a wire should attach to the load side of
the amp gauge. How do I know which side is the load side. Right now one wire goes to the ignition coil and the electronic ignition, the other wire goes to L
on the voltage regulator. One wire from the amp gauge goes to BAT on the voltage regulator. Can you help me try to figure this out? It does charge well,
even with the lights on. You can look at my previous post about SMTA and your response on the second page. Thank You, Ellis
