Were all 354898R1 blocks 123 ci?
with C-113 engine SN: 310300 & up the use of the larger displacement kit is possible. Below that there may be a kit with more cubes, but dedicated to
that block. The bottom of the block where the sleeve spigot hits the Oring is smaller in the low # 113 engines. Jim
This particular block does not have a serial number on it. It does have a date code on it of 4-15-X. The tractor it's in has a broken steering housing so I surmise they broke the front of the block and purchased a replacement somewhere along the line. It also has a Super A head (9052D) dated in '47 so there is a possibility they just upgraded it for the additional power.
I wish I would have known this when I had the oil pan off. I could have measured the bore.
Thanks for all the information. I do appreciate it.
