656 Rockshaft Seals
Using my Farmall 656 yesterday to mow, both sides of the rockshaft are seeping oil. Looking at the parts catalog, it's difficult to tell if the seals are located on the outside or inside of the housing. I was hoping to just pull the rockshaft arms and change the seals but now wondering if it might be a bigger job....removing bushings, blah, blah, blah, Can you guys shed some light where the seals are located? Also, there's a right and left seal which I find strange.....thought they'd be both the same.
Thanks for your response.
They are different because the shaft is bigger on one side be careful do one side at a time because there?s leakage inside in side the top
