A 460 doesn't use 'loop' style rims. They use the 'double bevel' type with wedge clamps. Unless you have a 460 utility......Or do you mean the 8 'spoke' cast wheel?
Power Adjust rims would have 4-5 rails, not 8. Even 38 inch rims only had 6. Demountable rims that
bolted to stamped steel wheel centers on 460 utilities only bolted at six spots. Double bevel rims used
on cast wheels on Farmall row crops used wedges, no kind of loops on the rims. The bigger wide base rims
IH used for 23.1x30, 23.1x34, 24.5x32, and 30.5x32, the 20x30, 20x34, 21x32, and 27x32 rims used riveted
on mallable iron lugs to bolt solid the the cast center wheels, but those size tires/wheels not used on
460's either Farmall rowcrop or Utility tractors.
Till the original poster comes back and clarifies what he really wants we can't help him.
(quoted from post at 15:30:34 07/29/18) Power Adjust rims would have 4-5 rails, not 8. Even 38 inch rims only had 6. Demountable rims that
I am trying to reply. I am new to this forum. I will talk to my dad tomorrow and try to get a picture for you guys.
Hey I finally got a thread threw. I have been trying all day. I am pretty sure it is a 8 loop. I can not find anything anywhere. I get some pictures tomorrow and get back to you. Thank you guys for getting back so fast. Really surprised me that you guys were that fast with info. I will be in touch
(quoted from post at 19:52:20 07/29/18)
I am trying to get picture up. How the heck do I do it.
A Utility would use 8-loop rims, which you can find easily with google.
Your local tire dealer is also a good place to ask. Any tire dealer that services tractors also has a source for rims, and can often beat online prices because they don't have to charge shipping.
Used rims? Your guess is as good as mine. Tractor salvage yards maybe? Don't know where you live so don't know what's around.
That's not an 8-loop rim. Notice there are no loops on the rim. The rim is held by clamps against a bevel on the rim.
You have a Farmall 460, or a 460 Hi-Utility.
That is what's called a "double bevel rim" because it has two such bevels on the rim. They are very common.
