Bansheetaz
New User
Well I need to replace the head gasket again on my 300.. 3rd time in 2 years. So now I'm looking for advise
First.. is felpro ok to use on these? I've used them with great success on many cars and trucks with no failures. Or is there a more preferred gasket.
Second... the gasket says to use sealer and to retorque. Would copper spray sealer be the thing to use?
Third.. when I retorque.. should I take the Tractor and do some plowing or is just running it around going to get it hot enough.. this latest failure appears to be from insufficient torque even though I did retorque. Maybe I need to check the head bolts 3 times.
Thanks for any help provided
