SadFarmall
I found a French chap today, who says he can work magic on the original temperature gauge for my F12, so I will try that first. He is also going to check the oil pressure gauge.
These things lead to me to consider:
1. The temperature gauge bulb is locating where it will do least good - in the bottom of the radiator. It does not really look like the head has many (if any) suitable places to drill a hole for a temperature gauge sender unit…
2. The location of the oil pressure gauge on F12 tractors is bad. The gauge is invisible from the driver's seat, unless you lean over toward the off-side rear wheel. When the tractor is stationary, that is all very well. When 54" steel wheels with 4" lugs are rotating, it is not so nice. Is the oil pressure gauge set under the fuel tank to keep it out of the way of a driven belt from the pulley on the off-side of the tractor? For originality, I suppose it should stay where it is. For use, it probably should be moved.
Any ideas, thoughts?
SadFarmall
SadFarmall
