Both the generator belt and the fan belt are loose on my H. I
removed the screw that holds the movable sheeve in place that is
used for tightening the belt. I sprayed PB Blaster into the screw holes
to get lubrication onto the sheeve threads. I tried to use a block of
wood and hammer to tap against the sheeve to loosen it so that I
could then tighten. So far no movement.
I assume there is a spanner wrench that can be used to keep the fan
hub from moving. Is there a similar tool for the tightening or loosening
the sheeve. How to you tighten the sheeve? What method have you
used to loosen the sheeve and get it moving?
