I replaced the points and the ignition coil, and was able to fire the engine right up. Feeling accomplished, I hooked up the cycle bar, and began cutting. Very quickly the tractor lost power, and was not able to restart. It was back to the original issue. My original cap position was with the clips at 12&6 o'clock. Once I had the engine running, it sounded better when rotated 60 degrees.This morning I rotated my distributor cap 135 degrees from my 2nd position and was able to fire the engine right up. As it ran, it sputtered and shut off. The gear from the distributor rotor looks good, but what do I investigate next? The distributor cap is not rotating, as the tab is in the proper location, and not loose.
