Hey Everyone. As you may have read previously, I have a "new to me" IH 444 with a 1501 Loader. I finally got her home, and was actually able to read the S/N under the layer of grease. I have #2248, a 1968. Anyways, I'm gathering up everything to get her serviced and ready for use here. My intentions are to drain everything and have a starting point for future intervals... especially since it sat for a couple of years. What coolant should I be using? The Operator's Manual did not specify a type, just a quantity. I'm guessing a regular glycol-based coolant would suffice, diluted 50%? Also, I have major confusion about the Trans and Hydraulic Fluids. The book says they call for the Hy-Tran Fluid; 3 gallons for the Hydraulic Reservoir, and 5 gallons for the Trans, with a long note, which I'm sure you're all familiar with; "Capacity is 5 gallons without front mounted hydraulic pump or draft control; 14 gallons with front mounted hydraulic pump - without draft control; or 17 gallons with front mounted hydraulic pump and draft control. I don't think I have the front-mounted pump it talks about in the note. Mine is mounted near the front on the side...I'm assuming the manual is referencing a pump located at the front, like in front of the grille? I do have draft control and a loader, though. So, I'm confused as to how much Hy-Tran I need to get? My last question (for now) is where does the power steering get its fluid from? I didn't see much in the book on the system other than it's capacity is 1 3/4 pt of IH steering gear lube, and it seems to look all self-contained. I have to replace a seal behind the steering wheel and was wondering how to service it afterward and with what?Sorry for the long-winded post. Thanks for any help you can provide!
