jesseholmz
Oil seeps out of the steering column and down the dash on my IH 574 gas. It was theorized here that it may be the seal. Looking at the diagram shows an o-ring that may be easily replaced. If it's pumping oil, it wouldn't be the pump right?
What's the difficulty in replacing the o-ring? A new pump is in the $900 range so I'm hoping it's not that. I've attached the diagram of the assembly.
