farmall 300 hydralic manifold from pump
dewy
part number. ....on part diagram....nunmber 31.....blew the hose on pressure side..its crimped on to steel manifold on one side...looks just like the picture on parts diagram.... how do i replace that side of the hose ,,,the other end has female end that screws to pump.....will take picture tomorrow got home late from walkin home ,,left tractor in field,,what a mess.....thanks in advance.....dewy
You can get a compression coupling good for hydraulic use that will go on your line after cutting the steel line. If not enough room before bend in steel line you may need to go past the bend. Should be just enough room before bend. Then a hose can be made that screws on the manifold pipe and will join the manifold fitting. If you can get the compression fitting with 3/4 pipe female threads on the other side a 3/4 hose and male 3/4 pipe and end and fitting to screw on pump end is all that's needed. End that fits pump is a common hydraulic fitting. Take old fitting and hose length and OD of steel pipe and most can fix you up. IH made a repair kit for those at one time that needed brazed to steel pipe. Your pipes were replaced or repaired sometime because the pipes with flex ends at pump didn't come out into F-350 production.
