I have almost no throttle response, if I move the rod on the left side of the tractor to the rear I get plenty response, just vary little from the seat and only on the idle end. I had to take the radiator off to get boiled out and a leak checked out so it's all open. I was thinking I should open the govenor and check the springs and thrust bearing and probably just replace them since I'm in there and they're probably old anyway...finally I'm thinking I'll check to see if the end of the rod at the carb is rubbing or jamming up on theside of the carb. I've attempted tomove the clevis end of the rod but the nut is welded on from years of rust. Am I missing anything,should I check anything else, any suggestions? Thank you as always, Anthony
